Okay so i have a problem with my suspension. My drivers side ride height is about 1/2 lower than my passengers side. This is a problem because now if i put a load in it and i hit a bump my tire is so close to the wheel hub that it could rub. It has a newer tein suspension in it. What could be going wrong for it to do that??
Wierd Suspension
its probably because you sit on the drivers side. unless you always have a passenger, you will gradually compress the spring on that side.
Eye Level Media - Commercial & Automotive Photography: www.EyeLevelSTL.comOriginally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
That is common on an older worn out suspension. Did you replace the suspension or did a shop do it?Originally posted by kkaiser7901 View PostOkay so i have a problem with my suspension. My drivers side ride height is about 1/2 lower than my passengers side. This is a problem because now if i put a load in it and i hit a bump my tire is so close to the wheel hub that it could rub. It has a newer tein suspension in it. What could be going wrong for it to do that??
Also make sure you do your measurements on a flat surface. .5 inch would be hard to notice. Also check the tire pressure and make sure you are good....
id say worn springs or bad spring hats.
i doubt struts cause they dont determine the ride heightWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Seriously? Are you serious? I mean... for real. Are you serious?Originally posted by steelbluesleepR View Postits probably because you sit on the drivers side. unless you always have a passenger, you will gradually compress the spring on that side.
No.
Check to make sure everything is installed correctly. Something is definitely not right. Pictures would make it much easier to help, as well.
I've never known a single spring to sag that much, even cheap crap. A blown shock shouldn't cause that much of a dip either.
Edit: for some reason I read things wrong... it's not quite as much of a dip as I initially thought. Worn parts or a blown shock COULD be the cause. If you lowered in on stock shocks, that's most likely the case. Lowering your car on 20 year old stock shocks is extremely stupid.
on a side note, my van has been lopsided since it was bought in 99 (i call it the mad shoulder lean) and its nOT CAUSE IM FAT! lol
so a blown strut can cause that? the reason im wondering is that i thought the strut is there only for support when it hits bumps and stuff...
whazzah devv!What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
heh yea my van is 2''Originally posted by deevergote View Post.5" could be done by a strut. For some reason, I was thinking 2"!
Retro!
Hater
