Question for the experts.
    okay well i submitted a thread about my car awhile back....it doesnt start, at all, doesnt seem like its firing at all....ive checked the fuel pump, injectors, spark plugs, main relay, even used a new distributor, and still nothing. everything works...and yet the car dont start...ive had like 6 mechanics come look at it, and only one got it to start and then it died...he said it was the distributor cuz the wires were all fucked up...and i got a new one but it still dont start...idk what it could be????? what yall think???
    did u change the coil and is ur firing order correct.
    my new turbo build
      have you checked you ignition switch? does the lights come on (cluster) when you about to turn it on? Have you also checked you starter? The ground wires? the Fuses? The battery? Have you checked your rotor? All those parts can be it.
        Have you checked if you have fuel and spark?
        My 5.7 LS1 Holden Ute
          yea i checked the rotor, battery, i changed the coil, yea the lights come on.....what ground wires???
            starter and fuses check out, yea it has fuel and the fuel pump works....it just wont spark...but i have new spark plugs, new distributor, and new lines???
              With the key in ON (II) position, do you hear a chime if the driver's door is open?
              1997 Honda Accord EX-V6:
              Originally posted by James Matteu
              You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
                what u mean a chime???? like coming from that one thing??? i took that out...
                  I had this problem in my old accord and it ended up being the ignition control module. I had changed out a bunch of stuff before my grandpa came by and said hey this is what it is so check that out if you havent already!!!
                  Time to Fix it Up
                    Chime. Bell. Ding ding ding.
                    I have no idea what "that one thing" is that you're referring to... but you're WAY more unclear than the guy trying to help you.
                    Honestly, all we know is that your car won't start, and that you replaced the distributor. Not all that much to go on, honestly. You're asking us to diagnose cancer by telling us what you had for lunch.
                    What is done to your car? What does it do when you try to start it? What do you hear? What do you see? What lights are on on your gauge cluster?
