Gauge Cluster Adjustment
    So i was at the local yard the other day and found a pretty decent lookin cluster for my ex for 25 bucks. i just wanted to know if anyone knew the specs for adjustment i.e. (odometer adjustment, fuel gauge , temp gauge, etc.) or is the instrument panel one of those things that shouldnt be fooled with, and i just wasted 25 bucks. if i cant get this one workin right i guess itll be time to cave in and start lookin for a JDM cluster but for now id still like to be able to adjust this one if thats possible.Thanks again all
    What do you need to adjust it for?
      I don't even understand this, is the cluster from another cb? maybe prelude?
      1993 Accord EX
      2011 Subaru STi
        As to the odometer, I'm sure that's adjustable but (technically) illegal to do so. But I don't know how.
        The other gauges are run I believe by reading a millivolt or milliamp setting off of the sensor for each gauge (fuel level sensor, tachometer, and speedometer, as well as engine coolant temperature gauge). the oil pressure sending unit is I believe just a 12v current lighting it up when the opsu closes.
        I have no idea how the stock gauges are calibrated according to millivolts, however, or if there's a way to mechanically adjust them as opposed to electrically adjust them.
        To adjust a milliamp reading in general, you can I believe apply a resistor to it, such as installing a potentiometer on the line and twisting it until the current changes to the right level. I'm not sure how to adjust a millivolt reading however off the top of my head.
        Not sure if that helps.
          i think that maybe this cluster was removed before and the srcews messed with , cause when i hooked it up some of the gauges started acting funny. the tach was unresponsive and it was jumping around , and my old cluster never did that. also the fuel gauge on this cluster shows that theres a half tank when i know its more along the lines of an eighth of a tank or less. does anyone know if messing with the scews on the back would somehow ruin all the readings that it should display ?
            Sorry to bring this back from the dead but I am having the same issues. I had to change a few bulbs in the cluster for a couple indicators and now my temp and fuel gauges are pegged and the speedo is off by 10 slow now. And all I needed to do was swap some bulbs. I need this thing to be dialed as it's my only runner right meow.
            Help??!!
