s2000 oil filter?
    s2000 oil filter?
    Can we use an s2k oil filter on our engines? i know its the same base, but if so, whats the reason for doing it? is it better?
    also, what weight of oil do u guys run and y? i use 5w30
    2013 Ice Cream Cruise!
    VIDEO: 2012 Ice Cream Cruise
    VIDEO: 2012 Ice Cream Cruise part 2
    The single largest cruise in the Midwest!
    August 3 ~ Omaha, NE
    By 1320 Video
    Member's Ride Thread
    i'm gonna go out on a limb here and say that a cb's oil filter is gonna cost less than a s2000's, so save your money and buy the one that's made for your car =)
    96 mx-6, needs work...
    91 accord lx sedan, needs work...
      Honda oil filters are all the same size, before 2003 there used to be to different size filter. Then they switched to just 1 size for all their vehicles. The s2k filter should fit without issue. There also should not be any price difference unless it's aftermarket. Like I said it's 1 oil filter universal to all model hondas, If I remeber correctly Acura still uses 2 different sizes.
        Is there an improvement if you use a different such as the S2K one?
          You won't benefit much as they all do the same thing.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            So what about when you buy an oil filter for your oil change, does the chep-o-filter do the same as the royal purple filter I had or does that actually help out with the filtering process?
              This is the numerical listing for NAPA P/N: 1334
              while the factory numbers may be different from car to car they all interchange back to this number.
              i highly doubt you would notice any difference from one factory filter to another. hence the interchange to one number.
              Acura 1.6EL 1.6 L 1590 CC L4 VTEC 1997 - 2000
              Acura 2.2CL 2.2 L 2156 CC L4 1997 - 1997
              Acura 2.3CL 2.3 L 2254 CC L4 1998 - 1999
              Acura 2.5TL 2.5 L 2451 CC L5 1995 - 1998
              Acura 3.0CL 3.0 L 2997 CC V6 VTEC 1997 - 1999
              Acura 3.2CL 3.2 L 3210 CC V6 VTEC SOHC 24 Valve 2001 - 2003
              Acura 3.2TL 3.2 L 3210 CC V6 VTEC SOHC 24 Valve 1999 - 2003
              Acura 3.2TL 2004 - 2004
              Acura 3.5RL 3.5 L 3474 CC V6 VTEC SOHC 24 Valve 1996 - 2003
              Acura 3.5RL 2004 - 2004
              Acura Integra 1.6 L 1590 CC L4 1988 - 1989
              Acura Integra 1.7 L 1678 CC L4 1992 - 1993
              Acura Integra 1.8 L 1797 CC L4 VTEC 1994 - 2001
              Acura Integra 1.8 L 1834 CC L4 DOHC 16 Valve 1990 - 2001
              Acura MDX 3.5 L 3471 CC V6 VTEC SOHC 24 Valve 2001 - 2002
              Acura NSX 3.0 L 2977 CC V6 VTEC DOHC 24 Valve 1997 - 1997
              Acura SLX 3.2 L 3165 CC V6 1996 - 1997
              Acura SLX 3.5 L 3494 CC V6 1998 - 1999
              Acura Vigor 2.5 L 2451 CC L5 1992 - 1994
              Honda Accord 1.8 L 1829 CC L4 1984 - 1985
              Honda Accord 2.0 L 1955 CC L4 1986 - 1989
              Honda Accord 2.2 L 2156 CC L4 1990 - 1997
              Honda Accord 2.2 L 2156 CC L4 VTEC 1994 - 1997
              Honda Accord 2.3 L 2259 CC L4 1998 - 2002
              Honda Accord 2.3 L 2259 CC L4 VTEC 1998 - 2002
              Honda Accord 2.7 L 2675 CC V6 1995 - 1997
              Honda Accord 3.0 L 2997 CC V6 VTEC SOHC 24 Valve 1998 - 2002
              Honda Civic 1.5 L 1493 CC L4 1988 - 1991
              Honda Civic 1.5 L 1493 CC L4 SOHC 16 Valve 1995 - 1995
              Honda Civic 1.5 L 1493 CC L4 SOHC 8 Valve 1995 - 1995
              Honda Civic 1.5 L 1493 CC L4 VTEC-E SOHC 16 Valve 1995 - 1995
              Honda Civic 1.6 L 1590 CC L4 1988 - 1991
              Honda Civic 1.6 L 1590 CC L4 SOHC 16 Valve 1998 - 1999
              Honda Civic 1.6 L 1590 CC L4 VTEC SOHC 16 Valve 1993 - 1993
              Honda Civic 1.6 L 1590 CC L4 VTEC SOHC 16 Valve 1995 - 1995
              Honda Civic 1.6 L 1590 CC L4 VTEC SOHC 16 Valve 1998 - 1999
              Honda Civic 1.6 L 1590 CC L4 VTEC-E SOHC 16 Valve 1998 - 1999
              Honda Civic 1.6 L 1595 CC L4 VTEC DOHC 16 Valve 1999 - 1999
              Honda Civic 2000 - 2000
              Honda Civic 1992 - 1994
              Honda Civic 1996 - 1997
              Honda Civic Del Sol 1993 - 1997
              Honda CR-V 2.0 L 1972 CC L4 1997 - 2001
              Honda CRX 1.5 L 1493 CC L4 1988 - 1991
              Honda CRX 1.6 L 1590 CC L4 1988 - 1991
              Honda Odyssey 2.3 L 2259 CC L4 VTEC 1998 - 1998
              Honda Odyssey 3.5 L 3471 CC V6 VTEC SOHC 24 Valve 1999 - 2002
              Honda Odyssey 1995 - 1997
              Honda Passport 2.6 L 2559 CC L4 1994 - 1996
              Honda Passport 3.2 L 3165 CC V6 1994 - 2002
              Honda Prelude 1.8 L 1829 CC L4 1983 - 1987
              Honda Prelude 2.0 L 1955 CC L4 1985 - 1987
              Honda Prelude 2.0 L 1958 CC L4 1988 - 1991
              Honda Prelude 2.1 L 2056 CC L4 1990 - 1991
              Honda Prelude 2.2 L 2156 CC L4 1992 - 1996
              Honda Prelude 2.2 L 2156 CC L4 VTEC 1997 - 1999
              Honda Prelude 2.2 L 2157 CC L4 VTEC DOHC 2000 - 2001
              Honda Prelude 2.2 L 2157 CC L4 VTEC DOHC 1993 - 1996
              Honda Prelude 2.3 L 2259 CC L4 1992 - 1996
              Honda S2000 2.0 L 1997 CC L4 VTEC 2000 - 2003
              Honda S2000 2.2 L 2157 CC L4 VTEC DOHC 2007 - 2008
              Honda S2000 2004 - 2006
              Honda S2000 2009 - 2009
                the cheapo filter is cheap for a reason.
                dont buy them.
                the performance filters do filter better, but only slightly compared with an OE quality filter.
                  im just using the OEM blue Honda oil filter with ENEOS 5w-30 oil
                    I use Hamp Synergy oil filters.
                    Raceline USA
                      The difference between cheap oil filters and more expensive ones would be the material they use and how well they actually filter the oil. I use the cheapest filters and oil but I do my oil changes every 3000 kms. Personally, I think that is a better way to ensure your engine lasts longer than buying an expensive filter. IMO
                        The s2k filter has a larger capacity which = more filter material. Definalty would be better to run it if you have an H22....but waste of money for the
                        F22.
                        My swap thread
                        Main relay proplems?--DIY
                          TONS of misinformation in this thread.
                          1)All Honda filters USED to be the same size. Then Honda decided that a smaller filter would work just as well in most cars, so they released the current filter.
                          2) The S2000 uses the same filter that all Hondas USED to use prior to the release of the new one, because of additional filter capacity. It is NOT recommended to use the new filter on the S2K.
                          3) You can use an S2K filter on any Honda car, but you can't use the new filter on the S2K. Honda released a memo specifically stating this to all of their parts departments. So if you want to pay the extra $ for the better filter, then by all means, feel free. Whether it is worth it or not is up to you, but there is clearly a flow and capacity difference, or there wouldn't be a restriction on the S2000. Of course, then again, your car probably doesn't rev to 9,000 RPM either.
                          4) The exceptions to the rule are the Hondas that were not actually made by Honda, i.e. the Passport and the Acura SLX. They use their respective Isuzu filters.
                            You wont see a preformance increase by using a diffrent oil filter.
                              I've used the M105 Mobile1 filter for the extra oil capacity on all my H22/H23/F23/K24 engines in the past because I've never thought added oil capacity was ever a bad thing. Having the extra filter media also is less of a restriction in case you forget an oil change in dusty/dirty environments.
                              The Napa 1334 is a filter made by WIX and it's been tested on www.bobistheoilguy.com to be a good filter both for quality of filtration and also assembly.
                              I've used both and am pretty happy about both kinds.
                              VTEC G27? = ???whp ???wtq
                              VTEC G23 = 220whp 191wtq
                              nonVTEC G23 = 200whp 183wtq
                              K24 iVTEC hybrid = 260whp 210wtq
