buying new cv joints/axles. abs?
    i'm in the process of buying new axles and some say w/ abs and w/o abs. i don't have ABS but will it make a difference? just wondering
    90 ACCORD EX..<-- MR thread
    im assuming it would make a difference.. if theres 2 diff types for a reason?
    with abs im assuming have something added in them and would need something your car doesnt have to power em? im not sure though just a thought.
      ABS have the teeth around the axle for the abs sensors. Non ABS doesnt.
        gotcha, thanks!
          Yeah the ABS ring is the only difference.
          I know....I'm gunna lower it
            I'm using an ABS axle in my non-ABS car for quite a while now with no problems. So you can go with the ABS version regardless. The reason I got an ABS one was that the non-ABS version was not in stock.
              u can also tap the abs ring off the end of the axel.
              my new turbo build
                autozone for lifetime replacement and core refund...
                Be Clean
                  ^^Yes^^
                  I was confused about this situation last year. I learned that there really isnt a differance between the 2 besides the ring. and you can tap it out if you want. I also learned that If you have ABS and if the parts store doent have your axle w/ABS but they have the one w/o ABS, you can tap out your OEM ring off the bad axle and install it on your new one.
