To make a long story short,i own this cb for 2 months and when i got her the previous owner seem to have use some sort of radiator stop-leak to temporary fix the radiator.
So i changed the rad and flushed the coolant since it was very dirty.
The temperature gauge was kind of low and my heater was not pulling enought heat so i changed my T-stat with a auto part one.Nothing changed.
I read on here that honda have issues with non OEM one's so i replace it with a genuine one.No result.
The problem is that now,i don't get more heat and i can't bleed the cooling system.When i start the engine,the cooling rinse right out of the rad so i have no choice but put the cap back on.The engine is cold,so i don't get it.Can a OEM T-stat be faulty?
The lower rad hose is cold,and the upper is hot.The lower one tends to get warmer toward the engine side.
Now this week-end,i want to take a last shot at it before the cold settle in.
What is the right procedure for flushing the heater core?Can i simply unplug the hose at the heater valve and the other side inlet and plug a garden hose?
Since i found large residus inside the T-Stat housing,how should i flush the engine without damaging the water pump?
http://www.cb7tuner.com/vbb/showthread.php?t=144444
Thanks everyone for your precious helps and hints so far
also if your going to do a complete flush of the cooling system you should open the block drain plug just next to the oil filter and get the excess coolant outta there before flushing it, and like accordztech said dont forget to loosen the bleeder screw on the thermostat housing until a steady air bubble free stream starts to flow. hope this helps a bit
