i have an engine question i recently traded my ef for this 92 ex 4 dr auto and the code on the block says f22a6, i looked at chilton repair manual and it says :
1992 dx/lx f22a1 hp135
ex f22a4 hp125
ex-r f22a6 hp140 i know the hp is wrong in this manual, so do i have the stock engine or not and how do i found out if its the se, ex-r or 93 ex engine or is the manual wrong on that too, well this brings me to the next question about vac hoses
my number 12 hose is disconnected , its connected to the intake manifold and it seems the other end was connected to something plastic cause it has a piece of plastic in it and the hose that should connect to the engine mount control solenoid valve is connected to the bypass control solenoid valve then it goes down to were it should go... so is it wrong, the bypass control solenoid valve is on the top center of the fire wall right or em i wrong please help... thanks
ex f22a4 hp125
