Ok, I pick up the f23b1 tomorrow and will get the ecu out of the car as well. Thanks
91 Accord Ex build...
What do you mean? I currently have a f22a4 engine in my car, that's giving me problems. I'm picking up a f23b1 vtec. I'm not sure where f23a1 came into play...I'm very mechanically inclined; I worked on cars for about 8yrs with my uncle. If I tear it down I can put it back together. I haven't tried and engine swap before so that's why I have so many questionOriginally posted by deevergote View PostF22B1 or F23A1?
Are you sure you're going to be able to do this swap? You don't even seem to know what engine you're picking up...
If you want simplicity, I would get the 94-97 Accord EX 4cyl motor (F22b1), assuming the block is in good condition. I'd only use the block and send your current F22ax head for reconditioning, slap it on. I'd replace any necessary external engine seals and do timing belt/water pump job and be done. This can retain your stock engine management system because you have essentially built another F22ax engine. The F22bx blocks are same as F22ax.
If you're willing to put a little more effort for some performance increase, get the F23 block, if in good condition. Use that block and recondition your F22ax head, slap it on. This will give you more static compression and slightly more stroke. Basically, it will be a torquey motor for a 4 cylinder. This will require a chipped ECU with dyno tuning, so you may as well throw in a slightly more performance-oriented camshaft to get more of a bang for the buck, since you have to get tuned anyways.
Either route, keep in mind you will have to invest more than just the initial purchase of a replacement block to do the job right and have it last you. Otherwise, don't even start the job if you intend to half-a$$ it. You're better off having a professional do an entire rebuilt motor replacement, swap a full good used engine replacement or just get another car.Last edited by HondaFan81; 11-09-2009, 09:43 AM.
I'm sorry its a f22b1
