*H23a1 turbo build
    *H23a1 turbo build
    i messed up....to all you guys that have been helpin me today i realized that i do not have an h22 i actually have an h23 im wanting to know if they are still able to be easly swaped into a 1990 accord and if they are a good canidate to be turbo'd and built with forged internals or am i just wasting my time...
    iv been told that the lower compression on the h23 is ideal for a turbo nitrous set up
    if your asking this question then your still semi new to the whole turbo thing.
    if you already have a h23 its def a good start. motor runs some good setups before and will continue in the future.
    all depends on your plans and how you drive the engine. but def capable of making 400hp out of and easier to work with if you plan on doing your own tuning starting off. the h22's are a lil more tedious.
    you mentioned internals, what exactly are your plans?
    MadLab Racing
    Southern Maryland
      i plan on gettin manley rods new main bolts and bearings pistons crower springs ane retainers fererra valves and a port and polish pretty much everything but getting the block resleved
        The H23 has FRM sleeves. If you want to run forged pistons, you're limited to the Mahle Gold Series pistons designed to work with the FRM sleeves... or you MUST resleeve it.
          is there anything wrong with the mahle pistons or are they junk that wont last id rather go weisco or CP
            Mahle pistons are good. For the FRM sleeves, they're your only option.
            If you want anything else, you MUST resleeve. If you want to make lots of power, resleeving would be smart anyway.
              I will have to relook, but I read somewhere, someone used Ferrea valves, and it def needed a custom job.
              the ferrera valves were bigger and needed custom work.
              From this thread:
              "Even the Ferrea valve train does not work with the f22a head. If you get the Ferrea complete valve train, You have to get the setup for the F22b2, And use only the springs, retainers, and raised spring seats.
              The valves are smaller than the F22a, and Ferrea and everyone else that makes bronze valve guides DOES not know the right size for the single cam.
              so make sure your good.
              MadLab Racing
              Southern Maryland
                That was regarding an F22A, though. This is involving an H23A1.
                I think cpmike had bad luck with a Ferrera valvetrain in his H22, though. I could be wrong, but I think that's what it was.
                Honestly, I'd go with Bisimoto for all parts. They're small, knowledgeable, and thorough.
