i have a P14 ECU out of a 95 prelude si im building a h23a1 with a turbo and im wondering whats all involved with getting a ECU chipped
chiped ECU question
You really can't do anything with that P14. You'll want a P06 from a 92-95 Civic LX/DX.
The actual "chipping" of the ECU is fairly easy. Simply de-soldering some components and replacing them with others that you can buy in a kit.
Tuning the ECU is a different matter. There is a LOT to learn when it comes to tuning an ECU.
We have a subforum in the Performance section dedicated to ECU tuning. There are also very helpful websites like www.pgmfi.org and www.homemadeturbo.com that will provide you with tons of info.
A P28 will also work with Vtec disabled for H23.
As Deev said chipping is fairly easy to do, But get it tuned professionally and don't attempt to go boosting around on a basemap.
My 5.7 LS1 Holden Ute
Very true. A P28 will work, as will a P72... but those cost more to buy, normally.Originally posted by wed3k View Postp06 is cheaper and easier to acquire.
Moates products are fantastic. I have a Hulog on my ECU right now.
But yes... when you finally get things all situated, don't drive the car. Get the ECU installed, and get the car running on a basemap. Then either get a tuner to come to you for a street tune, or limp the car very carefully (towing it would be better...) to a shop with a dyno for tuning there. Dyno tuning will pull the most power from your setup. A street tune can even out the A/F ratio, and many good street tuners claim to be able to get close to dyno numbers... but only the dyno tells you how much power you're making.
