Ok weird thing here
...On a cold start, even after the car warms up for about 5minutes-I've got lots of white smoke out of the tail pipe. It goes away after I start driving it's fine. The thing is, the normal op. temp doesn't ever go up past a little lower than half on the temp gauge, doesn't climb even after the car has been running for a while, fan kicks on like it should. The smoke has a weird smell to it, at first I thought it might be a little oil blowby, like it was burning it or something, but I've been checking the level on the dipstick constantly, and everything's kosher.
Any advice would be greatly appreciated. I'd like to have to avoid doing a head gasket job, but I'm starting to think I might as well do it, a water pump, timing belt, and valve adjustment while I'm at it. It has some valve tap when cold
...On a cold start, even after the car warms up for about 5minutes-I've got lots of white smoke out of the tail pipe. It goes away after I start driving it's fine. The thing is, the normal op. temp doesn't ever go up past a little lower than half on the temp gauge, doesn't climb even after the car has been running for a while, fan kicks on like it should. The smoke has a weird smell to it, at first I thought it might be a little oil blowby, like it was burning it or something, but I've been checking the level on the dipstick constantly, and everything's kosher. Any advice would be greatly appreciated. I'd like to have to avoid doing a head gasket job, but I'm starting to think I might as well do it, a water pump, timing belt, and valve adjustment while I'm at it. It has some valve tap when cold
