is there any modifications that i would have to make to a H22 manifold if i wanted to put it on a f22? or is it a direct fit?
H22 Intake manifold?
major mods need to be done. no, not a direct fit. get an h23 manifold = direct fit2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
Originally posted by P3dr0 View Postdammit, wat r the main differences between a H23 and a H22
I would go for the h23a, take a look at my thread, were I had just finish installing my H23a manifold swap. laterLast edited by pedroalcala; 11-22-2009, 11:55 PM.
If you have an F22A6, you could just replace the plenum. Direct fit to the A6's runners since the plenum is the same as in the h23, they match.Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
Originally posted by shadowdlink View PostIf you have an F22A6, you could just replace the plenum. Direct fit to the A6's runners since the plenum is the same as in the h23, they match.
IMO
Originally posted by pedroalcala View PostSwapping the whole intake manifold is more superb.
IMO
I did the swap and decided to go with A6 runners, because I needed to pass the state inspection(by cleaning the EGR ports).
Also, another plus to the A6 runners is that you can use the mount/support under the runners(the one that connects to the engine), to support the weight of the IM to prevent future distortion if any.Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
Originally posted by shadowdlink View PostRight, but there are also advantages to having A6 runners. Like access to the EGR ports. The EGR ports on the H23 IM runners are sealed, unlike the A6's which are just sealed with plugs.
Originally posted by pedroalcala View PostYou can swap all those parts directly to the H23 manifold, I swapped mine and I did the smog check a month later and passed.....is all up to whoever.....to each his/her own..
Originally posted by 93JDMBeast View PostP3dro ! LMK If Ur Gonna Need The Manifold Cus I Got A H23 One FS
I Live In ORLANDO Also ! LMK
Its direct bolt on if you only do the h22 plenum swap on my f22A6. I did the plenum swap. The only hard part is the coolant hoses in the back. I accidentally messed mine up and had to buy new ones, but it needed replacement anyway. Its tough to reach and pull them out. You Also need to buy a 3 way vacuum hose connector for the rear mount solenoid hose and the hose from the firewall near the passenger side. the h22 manifold has less ports than the A6.
