ok today i checked my H's compression and 2 cylinders had 210 and the other 2 had 260 and i checked them 3 times and i got the same readings. i took off all the spark plugs and disconnected the fuel pump and ecu fuses to do the test and i had the gas pedal held all the way down when i was cranking ! why am i gettin these readings is there something wrong or is that good and no there is no oil leaking into the cylinders to throw off the reading. can someone please help
h22 compression is not right
Those are good numbers. However the two lower ones are the ones to be concerned about. Now the previous poster said if they are opposite as in 1 and 4 cylinder have the low readings then i would do a leakdown test to insure backup. However it could be your rings (more than likely) or valve seals. But if it is on cylinder 2 and 3 i would almost say it could be your head gasket.
no way thats to much. all the ones that ive help joser, d112crzy tested about 230 and lower.Originally posted by 93layback View Posti read somewhere h22 compression should be alround 250-275 i wonder if he"s rings are going out ? what you think guys iam not sure if my number are rite i read it years back ..
do a leak down test to see if its just the valves.
What made you want to do a compression test ne ways?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
loss of compression is a sign of head gasket "damage". Head gasket goin out just a tiny bit, between 1 and 2 could cause this. You dont always have to have water in oil, vice versa. And a head gasket is the easiest fix IMOOriginally posted by kispirit17 View Postand there is no signs of head gasket damage
lots of things can cause loss of compression not just a blown head gasket. like rings or a bent valve.Originally posted by 93.4dr.22A1 View Postloss of compression is a sign of head gasket "damage". Head gasket goin out just a tiny bit, between 1 and 2 could cause this. You dont always have to have water in oil, vice versa. And a head gasket is the easiest fix IMO
yes you are correct there are like 7 or 8 different things that could be the problem. But almost always when 2 different cylinders are down in compression right next to each other it almost always points to a headgasket problem wether the car is smoking or oil in the antifreeze or vise versa. Yes we could be wrong and its just the rings but next to each other its usually a headgasket.
