True dual exhaust?
    Originally posted by apuforyou View Post
    Make an exhaust for each exhaust port, that's thinking at it's best!
    what why would u do that.. your loosing all your back pressure then. just get a cat back system and you'll be fine..
      back pressure really isnt as big of a deal as people make it up to be
      http://www.uucmotorwerks.com/html_pr...torquemyth.htm
      Click it.... You know you wanna
      Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
        Sarcasm
          You don't want back pressure. Ever.
          However, the exhaust flow from each cylinder, when the exhaust runners are tuned correctly in the header design, will result in increased flow velocity. The exhaust flow can actually pull the burned gas (and sometimes even part of the fresh charge) out of the cylinders. This is called scavenging. This wouldn't happen with a system that pipes out each individual cylinder, or even two at a time. A true dual exhaust system on a 4 cylinder designed to have all 4 cylinders' exhaust merged in a single pipe won't help anything. It would only hurt performance.
          And the S2000 does not have a true dual exhaust. The exhaust from all ports runs to a single pipe, and that pipe splits at the end.
