main relay question, please help!
    When I bought my car, it doesn't have the main relay, there was a wiring on the plug and the fuel pump was working directly. When you turned off the car you had to disconnect the batt for turn off the fuel system. I've to put a switch on the wiring and it works like a fuel kill switch, because when I tried a new relay, it doesn't work. Do the car needs the main relay to make any other things work properly? In fact, what's the total function of the relay?
    I forgot to mention that the main relay tried was a good one, tested on other car and working. My car is having a few electrical issues right now and i'm looking for any posible causes of those...
      Sounds like someone did a rewire job on that car. What other issues electrical issues are you having??
        X2!!!
        MRT H22A - 302whp - N2O
        MRT F22B - 643whp - 529tq @ 30psi
        11.33 @ 131mph @ 27psi
          your probably going to have to restore your harness to originally intended wiring then the main relay will work.
          member ride thread
          DIVULGE MOTORSPORTS
            other electrical issues? ok, It's seen on the function of many devices, ex; the power windows is working kinda slow, the dome light (roof light) is too weak, same problem on the power locks, the rpm gauge isn't working etc...
              If other systems need the relay, i do that. And that's I want to know. the complete use of the main relay.
                refer to a wiring diagram.
                member ride thread
                DIVULGE MOTORSPORTS
