HELP with gas mileage
    okay so heres my situation
    i have a 91 accord EX got for xmas
    84k miles and counting VERY mint car
    never really was maintained except oil change
    air filter and spark plugs were from 91 but i changed them lol
    have a SRI now and its an f22a4
    but im getting horrible gas mileage i had in between a quarter and half yesterday
    went 48 miles and im restin on the E line
    my car is lowered and does have negative camber but i dont think it would affect something that great?!?
    would someone PLEASE tell me what i need to do to get better gas mileage
    i will check tire pressure tomorrow and im cleaning my O2 sensors also
    i will replace them and alot more when i get my income tax back
    just someone guide me in a direction where i can get better mileage
    Thanks
    -Tyler
    How much gas was in the car?
      gas gauges are not always correct. Fill the car up reset the odo. and check the fuel mileage the proper way.
        between a quarter and a half
        and i will do that when i get the money to fill it up
        -Tyler
          odds are your cars gas mileage is fine. Alot of people have that issue. the floats get sticky, and dont function properly. My car does the same thing, I can go bout 200 miles b4 hitting the halfway mark, and i'll be lucky to make it 100 miles below it.
            timing belt,adjust valves ,o2 sender not bosh ,honda trans fluid,check brakes- make sure they are not dragging,alignment ,plugs,cap&rotor,,,30mpg is what you should get
              word
              i was planning on doing most of that when my check gets here
              NTK O2 sensor
              and im going to the honda dealership for anything im keepin it all OEM
              -Tyler
                I'd do like 93.4dr.22A1 said, fill it up and get a more accurate measure of your mileage. Once you have this info, then make the other adjustments (O2 sensor, etc), and you'll see how much of a change you actually made.
                Previous: '92 Accord EX Coupe
                Sold To: zack_odom
                  cool i go a little nuts on my cb ...lol it`s got 112,000 on it..a 90dx....o and most important new thermostat
                    tire pressure was around 40 on all 4's!!!
                    i havent checked it since i lowered it maybe that did it
                    but its at 30lbs
                    the door says 28
                    this could have led to a disaster
                    -Tyler
                      Well what I would do, is check your fuel filter, plugs, wires, air filter, and O2 sensor, cap and rotor.
                      Also pay attention to how many gallons your putting in, and reset your ODO, and see what your gas mileage is.
                      As stated above are cars gas gauges are not that acurate. lol.
                      HTH's
                      My System
                      http://www.cb7tuner.com/vbb/showthread.php?t=165155
                        How horrible is your gas mileage?
                        22 - 23 MPG is average. Any mpg below 22 is horrible.
                        I suffered 17MPG on my CB7 because it was running very rich.
                        You can even smell the unburned gas on the exhaust.
                        Some unmentioned factors are:
                        - Clogged EGR ports
                        - Clogged cat
                        - Mafunctioning spark plug wires
                        - Incorrect igniton timing
                        Check all of the other fellow members said and follow these also.
                        PS: You cannot clean an oxygen sensor. These are extreme sensitive components that don't want their tip to be touched by anything.
                        Recommended replacing the sensor instead of cleaning it.
                        EXTERMINATE ALL MUFFINS!
                        I WANT YOU! TO JOIN THE CAKE MILITARY SERVICE.
                        DO YOUR PART! FOR YOUR SWEET-TOOTH!
                          busted high pressure fuel line?
                          92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                            - Clogged EGR ports
                            - Clogged cat
                            yes i found that out by asking my auto teacher this morning
                            and how would i go about cleaning egr ports/valves
                            they shouldnt be bad since i only have 84k miles
                            wires and cap are from 91 but have new ngk iridiums
                            found out in that process need new spark tube seals
                            thanks all for the advice
                            -Tyler
                              but its at 30lbs
                              the door says 28
                              You would have been fine (Unless the tires are incredibly old and shot). The door jamb recommends 28 lbs for ride characteristics but the tires themselves have a much higher max tire pressure listed on the sidewall. Check it and see. Although 40 is on the high end I agree. I run my tires at 30 psi dead cold front and rear. (I use a bicycle pump to adjust the pressure in them after the car has been parked overnight and it has been out of the sun).
                              I get 30-33 mpg on my 92 DX manual but autos get lower (in the mid-twenties is common).
                              Following the others' recommendation, fill the tank up all the way, drive 100-150 miles or so, then refill and see how much gas you actually used. Hopefully you don't actually have a problem.
