i put a new dizzy new coil and still no spark it had an alarm system but took it off . the guy i bought it from told me that sum one stole the radio and cause the car not start
h22a1 no start PLEASE HELP ASAP
Have you checked the fuses yet?
Did you put in a new or 2nd hand dizzy?
My 5.7 LS1 Holden Ute
its a 93 prelude fyi its not my car im trying to help a frien but it has h22a1 aem cam gears+ p/s and alt aem fuel rail aem cai dc headers i think thats it nothing motor wise.Last edited by thguyonthecouch; 02-06-2010, 11:30 PM.
main rely is for the fuel pump dizzy is the distributor and a coil is idk a coil packOriginally posted by McRae View Posti dont know what a dizzy coil is but i have come across no start problems with the accord and it could be distubtor or main relay faulty
will a f22 fuel rail work on an h22???Last edited by thguyonthecouch; 02-06-2010, 11:35 PM.
Just curous
I am just asking this to be sure, but how did you check to make sure that ignition is your issue (how did you check for spark) ?
Assuming you checked correctly, my first guess is igniter.
When did this problem begin, was it working before hand and suddenly just turned off and wouldn't start, or was it sitting and modified, and now it won't start?
[QUOTE=thguyonthecouch;2417055]main rely is for the fuel pump dizzy is the distributor and a coil is idk a coil pack
will a f22 fuel rail work on an h22???[/QUOTE
that might be right but i have had a couple car that would not start turn over great but had no spark so change distubor and still not start change main relay under dash two 10mm bolts holding up box with on plug to bottom of dash and starts up first turn of key may not be call main relay but that is what i was told it was called
Main relay
That is because it is called the main relay...
Anyway, it is easy to tell if fuel is your issue, just to be sure you can take the bleed nut off of the fuel rail, make sure to put towels around the rail area to catch fuel. Have a friend turn the car to acc and look for fuel, it should literally be fountaining out of the bleeder hole.
If nothing, or less then that have them actually crank it and look for additional fuel.
If you do not have a fountain fuel is your issue, you could also get a fuel pressure gage from harbor freight, use it then return it, lol.
If fuel is the issue, then the first thing I would look at is the main relay, then fuel filter.
