I have the whole power door can and one tell me how to hook it up the car is a dx will it be plug and play or some mickey mouse bs?
Help with power windows
Hell naw, u just want a power window on that one door? That shit is funny. But anyways, the DX don't have power anything so I doubt its plug and play. There is a gang of wires and shit that goes from the door into the car, which I'm assuming the DX does not have being that it doesn't have power windows/locks/mirrors.
very trueOriginally posted by HardInThePaint View PostHell naw, u just want a power window on that one door? That shit is funny. But anyways, the DX don't have power anything so I doubt its plug and play. There is a gang of wires and shit that goes from the door into the car, which I'm assuming the DX does not have being that it doesn't have power windows/locks/mirrors.
Yeah cuz if he is just trying to do just the regulator and wires he's really trippin cuz thats a whole lotta work. U gotta get in there and put in the motor and replace the panels and wire shit up. Might as well just buy an entire new car, an LX or some shit. Installing the entire door would be the best way if ur gonna do something like that but I don't think its happening regardless without gettin real crazy.Originally posted by AccordFan_18 View Postwhat are you trying to do? be more specific
are you trying to put the whole door on? just the window regulator? wires?
Haha. "some mickey mouse BS?"
I understand your question. Check to see if your DX, even though produced without any motorized moving parts in the door, still have the wires tucked up somewhere in the dash.
It's kind of a 50/50 thing, I've seen some car manufactures use the same wireharness on all cars, just take out the actual components. Apparently it's cheaper to produce one wire harness and just not put in the components than it is to make a few different harnesses.
If it DOES have the harness going to the door, then it should be very simple. Either extending some wires, or just pulling them into the door.
If not, then you'll have to wire it up yourself. Which then..it may end up being some, "mickey mouse bs", as you previously stated.
Now that u mention it, my homeboy a couple years back tried this same shit in his 94 Civic SI. He snatched up a door from a couple (which has all the power bullshit) and thought maybe he could just swap the door out and then he'd have power windows and what not. From what I can remember I think it was way more complicated, he had to get behind the dash of the coupe and get all the wiring and shit. He didn't end up ever doing it becuase of that. IDK, they both Hondas so I'm assuming it'll be the same. Unless he was doin something wrong or maybe the DX is different. Like I said, IDK.Originally posted by npor View PostIt's kind of a 50/50 thing, I've seen some car manufactures use the same wireharness on all cars, just take out the actual components. Apparently it's cheaper to produce one wire harness and just not put in the components than it is to make a few different harnesses.
The switches are in the door so it shouldn't be too bad, you'll need to get the wiring schematics to see how an LX would be wired but theoretically all you need to do is ground one side of the switch and provide power to the other side. The door you're swapping in should have all the other needed wiring between switches and motors already prewired.
If you want the power lock button to operate both doors you'll have to run at least one wire from one door to the other as well, still not a big deal.My Member's Ride Thread
So i am thinking about doing this Around summer time so what im getting is imma buy auto doors and since our fuse boxes have the fuse spots for it would it be super hard? Becuz i got a friend who is crazy good with wiringand he said if i research and stuff he will help but what im getting is that it should not be to hard?
Mickey Mouse?
lol jk man, please search though--took me about 30 seconds.
http://www.cb7tuner.com/vbb/showthre...t=power+window
Hope this helps.
life is good.
