'S' light plus check engine lite help please
    Originally posted by union76 View Post
    I checked the IACV connector and it has power going to it...I just cleaned the IACV with throttle body cleaner before this problem so I wonder if that has something to do with it? On another note...the engine also has a hard time starting and staying running now...it'll crank and then act like it wants to start but won't...on the 4th or 5th try it'll start and idle really low...did'nt have this problem before I cleaned it out...
    If codes 1 and 4 were from the S light, then those things are not the problems. wed3k misunderstood your post. Those are codes 1 and 4 for the CEL.
      6 and 14 were from the CEL; 1 and 4 were from the S light...I think I found the problem to the ECT issue...the connector was brittle and the wires were'nt really connected...when I went to move it they came out completely he heh...this was the connector right under the distributor...
        the iacv is probably hosed if it cant keep a good idle. you can only clean them so many times.
