ok head gasket may not be blown...
    right on man. good luck
      heres the pics of plugs and caps....
      oil cap
      rad cap
      my bad it was number 3 plug not 2 as stated before
      number 1 plug
      number 2 plug
      number 4 plug
      DailyRuNr
      RTeK72
      www.cb7tuner.com/vbb/showthread.php?t=171103
      B18CA1 and B18B http://pbckt.com/sA.d5W Hoping to get a 90-93 Integra sedan to put one of these in some day...
      http://tipthepizzaguy.com/
        any one know anything about the chemical test they can do on the rad to check for exhaust?
        DailyRuNr
        RTeK72
          anybody?
          DailyRuNr
          RTeK72
            hmm, may have to repost this whole thread to get feedback...
            DailyRuNr
            RTeK72
              My suggestion is to concentrate on the coolant level only.
              You mentioned you topped it up and lost some coolant but don't know where it went.
              My questions are:
              Did you just change your coolant recently?
              How long since you changed your coolant and then checked and did the top up?
              Did you check both the radiator and expansion tank previously and both was staying full?
              Is it needing a top up every now and again? How many times have you done the top up and how often?
              Rides:
              Accord
              92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
              96-AUDM-2.2 VTiS- Heather Mist
              CR-X
              88-JDM-Si- Black
              CR-X Del Sol
              92-JDM-SiR "Transtop" Motegi Edition - Silver
              95-JDM-SiR "Transtop" Daytona Edition - Silver
              92-JDM-SiR "Transtop" - Black
              Prelude
              91-JDM-Si-4ws "Si States" - Phoenix Red
              91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
              91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
              91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
                changed the coolant back in october...
                realized i didnt have the overflow resevoir filled...
                refilled on saturday night...
                plus topped of rad...
                weird tho, since then i havent had to add any....
                still have the hesitation issue briefly after starting the car, every now and then after making a few runs...
                checked ecu codes...yesterday
                not sure what shes telling me
                put jumper wire in, turn key, one quick flash, pause, then four long flashes, one quick flash, pause then repeats...
                is it telling me 1 and 41
                or....some other code
                if so says o2 sensor, that sux...
                but with this car since i got it the check engine lite has been on
                looked around car and checked codes back then and nothing from ecu but did find a plug in the wiring harness under the intake near the oil filter that was not plugged in, but cant find anything for it to plug into, its very short...
                so didnt really mind the check engine lite till now
                DailyRuNr
                RTeK72
                  Ok I believe you dont have a head gasket problem.
                  What happened is since you forgot to top the overflow reservoir the main radiator was operating with some air in it. Then when you filled the reservior the main radiator naturally needed more fluid.
                  Looking around i got the below expanation.
                  14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
                  41 Primary Oxygen Sensor - Heater circuit malfunction
                  I would look into the code 14 first (IAC) as this would affect your idle. Besides it doesnt cost a thing. Just an adjustment or clean. Find a posting on how to clean and adjust this.
                  If the IAC doesnt fix it i suggest going to your nearest junk yard and grab an oxy sensor from the same generation accord or 4th gen prelude. If it doesnt fix the problem then at least you have a back up oxygen sensor.
                  The sensor is on the exhaust just before the catalytic converter. So you will need to go under the car (safety is a priority especially in the junk yards where things are unstable and not necessarily standing on solid ground). Good thing is you can remove the sensor easily without removing the exhaust.
                  Let us know how you go.
                  Rides:
                  Accord
                  CR-X
                  88-JDM-Si- Black
                  CR-X Del Sol
                  Prelude
                    In addition i suspect the coolant your using is a cheapo variety and i dont recommend it.
                    If its not cheap then the price may not be cheap but the materials they used is the inferior type.
                    Use Honda only. The colour may be blue or green but it definitely doesnt look like what you currently have.
                    It may cost more but you will be able to leave it in there longer! So the savings would come out better as well as knowing its giving you better protection.
                    Rides:
                    Accord
                    CR-X
                    88-JDM-Si- Black
                    CR-X Del Sol
                    Prelude
                      thanx jdmdriver
                      after seeing the prices for a new o2 sensor
                      yea the junkyard was on my mind for sure
                      and gona look at the (IAC)
                      DailyRuNr
                      RTeK72
