Hello everyone,
I have had my CB7 for about 8 months now.
Lately with the rains, my car is always foggy inside. When I turn on the heater, extremely humid air comes out of the vents which also fogs up the car almost instantly. I figured out that I can run the A/C which will dry the air, but I have to turn it on and off every once in a while which is getting tedious.
The windshield will also fog up after I turn on the engine and cruise around without turning on the air.
Is there any obvious place that I can check to see where water may be leaking in? I have not found any water on the floor or in the trunk.
There are also a couple of other things if anyone wants to take a stab at it.
First, the trunk warning on the dash always appears to be on. It was infact draining my battery because it would leave the trunk light on 24/7. Removing the bulb fixed the draining issue, but the warning continues. Plus I would like to have light in the trunk again.
Second is the speedometer. I cleaned it, sanded it a little bit and reapplied the electric grease, but on really humid days the speedometer gets stuck. After shutting the car off and turning it on a few times it will usually start to work again, sometimes going crazy on the freeway going to zero and back to speed. Should I replace the whole VSS?
Thanks in advance.
Thanks in advance.
