So lately I have been traveling alot so of course I step on the gas alot more and open up VTEC more often. maybe about two weeks ago I stepped on the gas and it sort of felt as if VTEC was dropping in and out, almost as if it was lagging. I checked the ECU and its fine I swapped it out and it still does it. Any Ideas on where to start?!? help is MUCH appreciated, Thanks.
Vtec Problems :,(
Im guessing were talking H22 in a cb7 here..Originally posted by NJ_STAMPEDE_LX View PostSo lately I have been traveling alot so of course I step on the gas alot more and open up VTEC more often. maybe about two weeks ago I stepped on the gas and it sort of felt as if VTEC was dropping in and out, almost as if it was lagging. I checked the ECU and its fine I swapped it out and it still does it. Any Ideas on where to start?!? help is MUCH appreciated, Thanks.
So id check the wires going to vtec solenoid and the solenoid itself
You might try testing and checking the wiring first. The solenoid wire should be green/yellow and go to pin A4 on ECU. The Pressure switch wire is blue and goes to pin D6, and the ground wire is black/Red. Since it is JDM, the pressure switch signal at pin D6 may be wired to pin A4. This will also activate VTEC. Check for loose connections. Also, if you do have the pressure switch, check your oil level, as this will affect engagement.Last edited by WagonLX; 03-05-2010, 03:20 AM.
I have noticed that if your motor gets low on oil then it will do the same thing. You might want to check that just to be sure it's not a oil pressure problem, especially because you have been driving more and you have been going into Vtec more often.
After you are sure it has the right amount of oil I would start with the Vtec pressure switch like everyone else mentioned.1990 Accord four door EX + JDM H22A + JDM LSD H22 trans: Born 08/01/2003 - Killed 11/12/2008
1992 Accord four door LX + JDM H22A = New project.
Thanks for all the help/suggestions fellahs lol it was just I need more oil, I gotta keep a better eye on that crap I suppose, it went through that oil very fast especially since I thought that synthetic shit is supposed to last longer lol I just did the oil change like 2 months ago
I breathe down shit so hard, you could see sound.
