ok i notice that my cooling fan dont kick in when it reaches normal temperture..i check my fuse and its good i checked the relay its good too but i notice that theres four pins on where the relay sits and there a constant power,constant ground and a gound with the key...now the other pin is most likely the signal but i dont think there's any signal going through so if yall had this problem before it would help cause i was think.. since i did the auto to manaul swap that,that could be a reason..?? cause the two left over plugs for the tcu...but i have a manaul p13 ecu..do i have to do some other wiring that i should know of??
THANKS...
THANKS...
