Low Gas Light?
    Low Gas Light?
    Last night I was driving and I ran out of gas and my low gas light never came on and I've been noticing lately that it hasn't been coming on lately when I've been getting low on gas. Is there a way I can check it to make sure the light isn't bad? Thanks.
    well it could be the light. or it could be the miss sensor or wiring....
    VS
    Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
    MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
    1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
    MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
      idk what it could be but a question on the side....how many miles is left when it DOES come on?
      -Tyler
        normally I get around 410 miles to a tank and it comes on around 380
          According to honda i think its around 30-40 miles if i remember correctly. Its a moot point because our sensors arent very accurate after 17-20 years. When my light comes on it means a gas station better be within 5 miles of your location or your fucked.
            Yeah mine never comes on either When u turn your key slightly all your dash lights should come on.... Pretty sure how it works..... good way to tell if any lights are out etc
            Installing a turbo and planning to tune later is kinda like having sex and planning to put the condom on afterward.
              I've swapped 4-5 different clusters into my car for various other reason and the low fuel light has never worked, I assume the sender in the tank is bad.
              My Member's Ride Thread
                better question
                How much gas can you put in at the end of your tank?
                My light comes on with 1.5 gallons left in the tank.
                201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
                  My light doesn't work but when the needle reaches JUST under the E mark it takes 16 gal to fill it up.
                    light never turns on and ive gone down to the E before I fill up..
                    also when I turn my key it does turn on and stay on for a second before it turns off..
                    maybe your sensor is done with, this is an old car and its gona need stuff to be replaced sooner or later..
                    Rush
                    Originally posted by Darkcloud
                    Bought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
                    Originally posted by bmxicansd
                    so you got a boombox, sunglasses and rosettta stone?
                      LOL, you made me spill my drink.
                      On topic though, Mine turns on and off depending if I'm idling at a light/accelerating/cruising.
                      When it first comes on it's no biggie for me, like it was said in a previous post ~30-40 miles or however much you get on 1-2 gallons of gas.
                      Maybe keep a red can of gas in your trunk (Don't know if that's safe long term) the 2-5 gallon kind.
                        If ur depending on the gas light to make sure u don't run out of gas ur trippin anyways. When ur shit is on E, go get gas.
                          u top it off till it spills out??
                          i culdnt get more than 14 n mine...
                            I usually get another 1/2 gallon in after the pump clicks off by itself. Your needle is probably off a little. Let it get below the E mark next time if you want to run it almost dry.....
                              I went 50 miles on my light before I filled it up
                              Its wierd how it turns on very dimly depending on how "low" it is then it will get brighter.
                              Wierd how you guys have problems, my sedan had a gummed solid gas tank and mine still works
                              Your man for wiring solutions!
                              CB7Man's Coupe H22 Swap
                              CB7Man's Sedan Resurrected From The Dead
