turbo on semi-stock f22?
    I was wondering if anyone had turbo'd their f22 while keeping the engine stock.
    The reason im asking is cause there is a guy selling a turbo setup for the f22. i know ppl boost their stock d16 civics n keep them around 5 psi. i wanna know if my engine will blow up if turbo it n put it around 3-7 psi
    1992 Honda Accord Lx
    [/I][/I][/I]
    yo
    4rm what i heard u would need bigger fuel injectors and a strong head gasket to keep the rest stock
      no youll be fine running stock for like 5 psi. it will just wear your motor faster than without a turbo. which is very obvious
      You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
      Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
        idk
        if youre gonna put your foot to the pedal like i think anybody with turbo would do atleast get a strong head gasket
          I run 8 psi on a stock motor with dsm injectors
            Many here have used the stock F22 with turbo.
            I'm running a stock F22 myself (although being a new one) at 12psi on a Big 16G.
            There is alot more than simply bolting the turbo on and off you go.
            Injectors, chipped ecu, turbo oil feed / return lines.
            It all depends on what the setup your looking at includes, and the quality of the parts.
            My 5.7 LS1 Holden Ute
              Stock injectors WILL NOT WORK. They will underfuel the motor, causing a lean condition, which will lead to detonation.
              Installng even a simple turbo setup is stil fairly complicated, and you need to know what you're doing if you expect your motor to last any significant amount of time.
                FMU mike??? lol...
                Praise The Lowered...
                  I wouldn't trust tired old squirters with just an FMU.
                    blah.. your sarcasm strainer is at its end...
                    just to clarify and give good advice
                    450cc+new Fuel filter+good working stock fuel pump is fine for about 10-15psi depending on the turbo setup
                    anything past that.. and a walbro 255lph is at best minimal for having proper fueling..
                    wasting money on aftermarket fuel rails is pointless though.. as they are not needed for even 500whp
                      other things to conisder for turbo:
                      need to upgrade clutch
                      condition of exhaust manifold bolts
                      motor mounts
                      tires and alignment
                      stopping power.
                      a lot more is considered, obviously if you wanna go faster you need better clutch and in order to stop that power better brakes.
                      keeping all your power down with motor mounts, and things like that.
                      stock headgasket is fine on small amounts of boost. also realize with boost your gunna get addicted and want more and more power!
                      trust me, it never stops.
                      MadLab Racing
                      Southern Maryland
                        Carlos, I never know when you've managed to take something that SHOULD be a bad idea and figure out a way to make it work... You have a knack for doing that.
                          lol.. hence the avatar tag mike..hence the avatar tag....
                            OEM Honda head gaskets are the only choice for head gaskets. never get anything other than honda, yea they work but there is a reason why pro racers use only honda gaskets.
                            You will need bigger injectors and some form of tuning equipment.
                            I personally ran 14.5psi at 315hp on a BONE STOCK block for over 3 years with no issues.
                            member ride thread
                            DIVULGE MOTORSPORTS
                              Yeah but I'm pretty sure your engine runs on witchcraft and was blessed by jesus himself.
                              Member's Ride Thread
                              Originally posted by mercyboy
                              I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
