Base/SH (Atts) Axles fitment
    both of these model using the same axle or they differnet...
    Almost 90% sure its different because of the SH's ATTS.
    '09 Mini Cooper S (R56)♥
      http://www.hondaautomotiveparts.com/...artsSearch.jsp
      The answer to all ?s about part matching, look up one, write down the part number, look up the other one, compare.
        ok....well is fucking wierd.i look up the axle on the left from base model and is 33743 and the left from type sh is 33744 any different ??? or just because it stock number but not parts. what RMD mean anyway
          Different number means it's a different part.
          RMD means remanufactured.
            The axles are definetly different. In the SH there is a special ATTS box that is extended out twords the driver side so the axle on that side for sure will be different.
              well how come i went to checker for both sh and base driver side axle...and i search...the part for type sh and base model is both exactly the same..
                Originally posted by aclude View Post
                well how come i went to checker and i search...the part for type sh and base model is both exactly the same..
                Well, then go by what they say. When they're wrong, you'll know that they aren't the same axles.
                  i serous dont know if they are the same or not... but i rather go with what you guys told me....lol...
                    ok nevermind i have sh motor...lol...cause h22a4 come in both..base and type sh...that why the reason i am asked you guys.but thanks to this thread
                    http://www.honda-tech.com/showthread.php?t=2485184
                    i have sh block
                      i have sh block
                      Your engine block has NOTHING to do with which axle you need. What tranny did you use? THAT'S what axle you need.
                        The only transmission he can fit on that block is an SH transmission
                          Really? What up with that? (no sarcasm intended) Why can it only use the one tranny? I would think an H block would bolt up to any tranny another H would.
                            i am just stating out that i have sh motor..and sh motor come with atts .. and so therefore i check if i have atts unit...and yes i do..so i know for a fact that my axle is type sh and i have atts bolt it into the tranny..so therefore i know i have h22a4 type sh motor and tranny
                              the motor that u though u can use another axle or tranny to bolt onto an h block is the h23 or h22 base model....an sh motor only sh tranny can use..because of ATTS unit....like i stated above ...
