H22 Swap to CB3 accord carb
    What are the things i need to change to my CB3 to make the H22, I know that I have to change the fuel pump but i don't know wich fuel pump I have to use, since my H22 comes from a JDM accord SiR can anyone help me with that and help me on what else has to be changed to make the engine work perfectly on my side i'm looking for the lights body that goes on the dashboard with the CEL, and the Main relay with the conectors, but besides that I don't know what else to look for.
    Most of the member base on this site is from the US, and we didn't get the carb'd model CBs... help might be slow coming. Good luck to you!
      Thanks man I hope I get it
        I think one of our moderators MIGHT have converted from carb to FI H22... if I'm right, I'll definitely send him your way!
          I hope that MIGHT is not only a hunch =) thanks really
            Are you talking about Dutch Accord? He did indeed do the swap.
            I looked into the swap but I couldn't find any info on it at the time.
            OP - You will need:
            Fuel pump / Sender unit
            Fuel lines / Filter and brackets
            Dash and engine wiring harnesses
            ECU
            Fuel injected Gauge cluster
            Thats all I can remember needing when I was planning to do it on my old CB.
            In all honestly, It's a lot easier and cheaper to buy an already fuel injected car - all the little extras you need add up to more than you think.
            Edit: Found his thread - The pics are dead, but there it may still help you out - http://www.cb7tuner.com/vbb/showthread.php?t=1039
            My 5.7 LS1 Holden Ute
              I forgot about him! No, I was thinking Affandi once said he was carb'd... If I see Dutch around I'll send him this way.
                Yep!
                Carb'd F18a > PGM-Fi F22a > PGM-Fi H22a
                When the F18a got the boot, a JDM CB9 cut was available, hence it was fairly easy, everything was transferred, engine, trans, ECU, TCU, dashboard and all.
                Had to source a different fuel tank though, including fuel pump, lines etc..
                good luck!
                Click sig to view MR thread
                Links to other rides:
                Honda Accord Euro-R
                Honda Odyssey Absolute
                Honda City I-DSi
                Honda Stream
                  Can i tell y'all that mine is carb'd also. The thing i planned to do though is go all the way with a K20a head and K24 block. i can honestly say though, that this wont be done until 2012 (lol we just might be extinct by that time).
                  After looking through a couple of threads, i really didnt realise it was going to be that annoying (like pulling down the entire dash!!! WTF?! -_-). Then this guy popped in my head--> telling me "oh anything can be done with couple $$$$" wish i could knock his lights out
                  '91 Concord Metallic Blue. Status: under construction
                    Where did he put the ECU? behind the center dashbord like behind the radio or where it goes on the CB7??
                      in the passenger footwell.
                      Honda Accord Euro-R
                      Honda City I-DSi
                      Honda Stream
                        Good luck bro,i got a carb engine too but for me its not time for me to swap it to h22,post up some pics when u start swapping it (tu)
                          Unfortunately I'm not physically allowed to make the swap, had to send it to a mechanic for that =( I'm on crutches till september
                            Wich of this sensors is better? the Omni power one? http://www.statracing.com/buy/omni-tps.asp
                            or the Street imports one? http://www.streetimports.com/product_details.asp?id=991
                            Thanks
                              a tps is a tps....if you can source one of ANY honda other then a k-series motor...it will work. they are all the same.
