Possible Bad Ground
    Possible Bad Ground
    My neg battery post tack welds the wire.
    So when I start I get a pzzt then everything goes dead. I get out and tap the neg battery terminal a few time and she starts. So I checked the battery wires and all seems good. When the test showed that the negative battery wire has a current running through it.
    Any Idea on how I should proceed. I may not keep the car if I got electrical trouble.
    IridiumCore
    HCK-The Beginning
    Your drunk she doesn't look that good.
    Replacing the cable will fix the issue, but try cleaning the connections if you can.
    The cable gets corroded internally as well as at the terminal.
    My 5.7 LS1 Holden Ute
      you may want to check the ground at the transmission as well. take it apart clean it with some sand paper. But yes it could corrode internally. Corrosion can cause resistance and cause alot of issues.,
        Thank you gents. I am planning on looking into this today. I did notice a large portion of the negative battery cable exposed and postive cable rather long.
        IridiumCore
        HCK-The Beginning
          Little Off Topic
          Love the signature "Ignorance is not an excuse for stupidity" that fits into place with my foundation. The Iridium Foundation for the Eradication of Stupidity (IFES). Too funny.
          IridiumCore
          HCK-The Beginning
            Ok I have replaced the negative battery terminal. Man that thing looked really bad. So far the problem has not resurfaced but I am giving a while.
            IridiumCore
            HCK-The Beginning
