my car does not keep a regular charge when its on last night i was driving and i had the radio on and my healights (hid's) one of my hids went off and the radio also i would rev the car and a battery picture on the cluster starting lighting up so i tought it was the alternator came home and check the alternator by removing the positive on the battery but the car didnt turn off plz help i need serious people only!
Battery keeps going flat
if your running alot of stuff off the battery you could be drawing more amps then the battery you have is rated.
something like this would most def work.
they also sell altenators for the same reason.
http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622_____________________________
91 Accord F22B
Ah. Gotya. Same problem happened to me. On my car, the bolt that holds the pulley onto the alternator was loose, causing the exact same symptoms. The pulley could spin on the bolt, and then produced a low charge voltage at driving speeds, (2.5k RPMs and up)
but it seemed to charge normally when at idle. (under 2.5k RPMs)
tighten the bolt, and hopefully, those problems should go away. Just make sure the alt didn't kill your battery. (it did mine)Last edited by Skidd; 04-16-2010, 10:55 PM.
with a properly workin alternator you should be in the 14-14.6 range at idle.
under accessory load you should be in the area of 13.3 or more.
a fully charged battery should read 12.6 volts standing.
if you are reading ANYWHERE under 12.6 under load than you should replace your alternator if your battery is indeed fully charged.
an alternator is NOT a battery charger.
its only purpose is to recharge what little bit of energy you spent whilst cranking the engine over. they do not like being overworked due to an undercharged battery. if you overwork it you burn it out. pretty simple.
keep a strong charge on your battery at all times. this will make your charging system happy
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
Yes this is deff well said. I was on my to central mo and my alt went out and now is throwing sparks and smoking!! So when I get back I have to change mine out!!!Originally posted by H22artman View Postwith a properly workin alternator you should be in the 14-14.6 range at idle.
The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
i'm almost POSITIVE (no pun intended) that the alternator DOES charge the battery! Really what the hell else does it do... The alternator constantly charges the battery, all the time. And most cars run on the battery and the alternator is always recharging it. thats why they have voltage regulators... to keep from overcharging the battery. I will agree to an extent that you really shouldn't rely on an alternator to charge your crappy battery, but it will sure try. Yeah, it is somewhat hard on the alternator to run off of it all the time, (IE jump start your dead and never good battery) but lets face, the battery doesnt keep itself charged up, and something has to run all those lights and stereo and blah blah blah... Just saying
