swap h22 head
    swap h22 head
    i have a question for u accord lovers. i have a h22 head that i want to put on my stock a1 block the only prob. i have is that one of the valves on the h22 head is no good. i was just woundering if i could take one of the valves off the stock ead and put it on the h22
    No, you need an H22 Valve.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      where can i fine one besides using ebay
        Honestly just upgrade the valves
        NEW CB
        old Darkcloud : 1990 Accord EX MRT
        new
        DARKCLOUD : 90 ACCORD EX MRT
          Hondapartsdeals.com
          Intake valve - 14711-P13-000 - $18.01/each
          Exhaust valve - 14721-P13-000 - 27.19/each
          or you could try pricing them at your local Honda dealership.
          MR Thread
            theres a store on ebay that has ferrea valves for the h22 for 150 dollars.
              Why are you doing this swap in the first place?
                it just a thing im trying out
                  It won't get you much but an unreliable motor. You'll have a hybrid motor with low compression and a low redline, not to mention the combustion chambers are not the same size as the block's bores, so there will be an overlap. It has been done, successfully on a rare occasion... most I know of have blown up.
                    Come on Deeve, all you have to do is mill the head .030, bore the block to 86mm and run some OEM K20 pistons (rotated 180&#176 on a set of OEM H22 rods. Then you wouldn't have as much overlap and you would be around 11.5-12:1 compression....
                    MR Thread
                      For that amount of work, I'll just buy an H22! It was assembled by people that actually know what they're doing building a motor, unlike me... who would miss something small that would result in total failure...
                        MR Thread
                          That's the thing with headswaps... in the hands of a beginner, they're a disaster waiting to happen. In the hands of an experienced engine builder, they are a calculated risk at worst.
                          However, anyone that says "how do i put a h22 head on my f22a block?" is PROBABLY not capable of taking on that build as a calculated risk. Even with step-by-step instructions, there are things involved that require engine building experience to understand.
                          If you want to do a headswap... try assembling a completely stock engine FIRST.
                            my first timing belt was on my h23 headswap. it took me quite a few times to get it running correctly especially since i had to jockey between belts.
                            im suprised i didnt bend any valves.
                              so than should i put a f22b on my block
