coilovers
    coilovers
    any ideas, suggestions, comments?
    any info will be helpful
    got a 90 lx and need to know what type of coilovers would be best
    i just put some lowering springs but the handling still sucks
    not looking for anything too expensive
    im kinda on a budget
    thanx
    90 accord lx
    form > function
    Member's Ride Thread
    thanx
    How much money do you have to spend?
    Did you lower your CB on the original shocks? If so that will be the result of your poor handling.
    If your on a budget then full coilovers might not be the best option, but getting suitable shocks for your lowering springs will improve the handling 10x better.
    If you are interested in coilovers go with well known companies like Tein.
    Please do NOT use the coilover sleeve's which are a common lowering option, because they will make the handling worse than it currently is.
    My 5.7 LS1 Holden Ute
      it is lowered on the stock shocks, dats the problem
      i can get both rear shocks for about $25
      but the front struts/shocks are around $120 each
      they are kyb shocks
      my budget is somewhere around $200 to get all 4 shocks =/
      another problem i have is that i just installed a camber kit on the front
      and now my control arm is smashing up against the frame on every bump
      (dats da reason i need stiffer suspension to stop it from bottoming out)
      i need some serious advice
      90 accord lx
      form > function
        just keep saving dude
          Get the Koni STR.T's they are 235 shipped. http://neuspeed.com/products/product...type=ns_import Theirs your shock problem but IDK what would be best for springs.
          Click picture for MRT
          Sparkin CB7
