The other day, when sitting in a drive thru, my car, a '91 Accord with a stock F22A1, began missing, as if it were running on three cylinders. It will mostly run normally when Idling/coasting, and intermittently run normally given light acceleration, but upon accelerating will miss/sputter as if it is running on three cylinders. The acceleration is atrocious and the fuel economy has dropped sharply. Upon starting, it will run normally, but after about 30 seconds or so it will begin to show the missing/sputtering symptoms. I am not getting any sort of check engine light, though I have gotten an unexplained (as in, no symptoms) code 43 in the past. I have recently (last 5,000 miles) replaced the oxygen sensor, the distributor is relatively new, and I changed the plugs to no effect. Also, the head gasket has a *slow* leak, but it's had this same leak for over 20,000 miles.
Any ideas? From what I've read, I'm thinking the EGR ports are clogged.
