HID question, HELP ME!!
    I just recieved my hids from trips customs. installed. only my drivers side works. swapped everything over and both ballasts and both bulbs work. put my stock bulb in the pass. side and it works. WHY WON'T MY PASSENGER SIDE HID WORK?!? this is pissing me off. someone tell me what to do.
    Originally posted by scudweiser
    once again people, need i remind you that there is no road between the kitchen and the bedroom, and therefore women need not drive?
    mines has done the same just flicker it turn it on and off see if that works if not take it back!!
      sometimes you have to reverse polarity in the stock wires. if the above ^^^ does not work, take some extra wire and see if switching polarity works. thats what i had to do on one of mine, and what my instruction manual told me to do.
      i wish i only had to turn the bulb around rather than having to cut and turn the wires around
      i really do hope that your problem is not that you have to flick the lights on and off to get them to work, because that means you may have to do that every time, and after awhile it can get annoying
      _
        tried switching the connection to the ballast because it has a pos and neg side, didn't work. tried flickering them on and off. still didn't work
          Call customer service. More or less you got a defective set.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            They are produced by xtremes hids but where I bought them from told me to consult them with problems but unfortunately they won't be open until monday.
              so your saying on my stock headlight harness, cut the wires and switch the pos and neg?
                yes
                according to the instruction manual i recieved, (ebay kit, non digital), one of the trouble shooting things i had to do was switch polarity.
                stick two wires in the oem connector, then connect them to the hid setup in a reversed fashion, then have a friend turn your lights on while you hold the wires carefully. if it works then switch polarity of your oem wires, if not you may need to wait until monday and call customer service
                waiting two days is not a BAD thing, theres people on here waiting many months prepping their car to be drivable again
                _
                  Check to see if you are getting 12v at the feed into the ballast - you may have accidently blown the fuse.
                  My 5.7 LS1 Holden Ute
                    yes
                    mine said to do this also but I didn't know what it meant.
                      tried switching the wires, still didn't work?
                        so I guess I didn't swap the ballast over. but I swapped it over just now and I have a bad ballast. that's why that side didn't work. I swapped the good one to the pass. side and it works. problem solved
                          mine had the same problem and i connected neg with pos and pos with neg and it worked
                          "Times keep changing, from rice, to jdm, Tucking to Flushing"
                          93Civichttp://www.cb7tuner.com/vbb/showthread.php?t=160321
                          92Accordhttp://www.cb7tuner.com/vbb/showthread.php?t=158283SOLD!
                            neg with pos. on what?
                              hes talking about switching polarity
                              you said you tried that already.
                              _
