just found out my vtec solenoid was bad
    Just found out my vtec solenoid was bad on my h22, is $70 a good price for a use vtec solenoid?
    That solenoid rarely goes bad. Is it wired correctly? did you remove it and clean it up??
      what makes you think it when bad? like excalibur02 said the solenoids dont go bad very easily 9 out of 10 its something else
        i had a mechanic check it out and he shot power to the solenoid and it still wouldnt work so he was saying that it was bad, i guess i gotta double check him
          Check the ground that's supposed to be from the oil pressure switch.
          Maybe that went bad and when he shot voltage in it didn't work...
            vtec solenoids dnt go bad it's either ur speed sensor or ur oil presure sensor that's bad n if u do change it make sure u go to honda n order the solenoid gasket it's
