A while ago my fan started to run when I turned my car off. I found it odd because my car wasn't running hot, and it never did it before. My mechanic said there was only a problem if the fan didn't run though, so i thought nothing of it. But tonight my temp gauge started to get really close to the top, but then it would just randomly drop to about half way to 3/4 again. It would keep doing this, I would even speed up to like 35-40 once it started to read hot, and the temp would go down again. After i got home, i popped the hood and felt the engine, and it felt a little hotter than normal, but it wasn't steaming or anything. But the temp gauge was reading hot again. What do you guys think is wrong with my car? I think i'm going to lightly spray the radiator with a heated pressure washer to clean it out, however i doubt that this would affect the temp this much, considering it doesn't even look that dirty.(besides things like the occasional bug or something)
Overheating problem please help!
It could be a few things.
First thing that comes to mind is the thermoswitch for the fan when the car is running (by the thermostat housing, 2 wire connector). The one at the front of the engine is for turning on the fan after the car is shut off (which you confirmed as working). Have you seen the rad fan on while the car is still running? A fan that doesn't run while the car is on would explain the temp rising then lowering when you speed up (more air flow through rad).
May also be a thermostat that isn't opening fully, or as you mentioned, a clogged rad or dirty rad fins on the outside, or low coolant.
ill have to check if the fan is running when the car is on, if it isn't i'm going to feel like a tool. lolOriginally posted by YK86 View PostIt could be a few things.
will do thanx for the advice dude.Originally posted by old honda tek View Posttake off the radiator cap and make shure the radiator is full of coolant,then put the cap back on and start the engine and let it run at idle and warm up and just let it keep running and watch the temp gauge , have a seat next to the engine and watch to see if both fans cycle on .........
