Removing camshaft
    Removing camshaft
    Anyone know of a camshaft removal/replace DIY on here? I looked and couldn't find one. Is it as easy as removing the valve cover and detaching the shaft from the camshaft gear? I understand when the shaft is reinstalled, timing needs to be set, etc., but I'm just concerned with the removal process for now.
    91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
    Neuspeed Super Cup Kit (7/2010)
    TAS rear drum-to-disc conversion (6/2010)
    Above photo taken - 4/2010
    Removal is pretty easy on the camshaft, remove the valve cover, undo the timing belt from the cam gear, unbolt the rocker arms, and the camshaft should come out.
      get a manual, there some online, just google accord service manual.
      member ride thread
      DIVULGE MOTORSPORTS
        The factory service manual covers removing the engine or changing the headgasket, but servicing the valvetrain would be the F-series engine manual, which is referenced in the Accord manual but I've never seen online.
          you can NOT just pull the cam out, you have to remove the caps in a specific order with the engine at TDC or you highly risk snapping a cam in 2.
          Go buy a haynes manual, it tells you exactly what/how to do. And you WILL need the haynes later on as well.
          and finding something in the manual is much faster then getting advice online...and far more accurate.
          ____
            Well I guess I must be lucky, when I went to a junkyard for an a6 cam, I just popped off the valve-cover, undid the timing belt, undid the rocker arm caps in no particular order, and the cam came out in one piece.
            Although the donor car wasn't mine, and I didn't give a f*ck about it, all I cared about was getting the cam out; if I was to do it to my car though, I would have had my haynes manual out, followed every instruction step by step, it is like heart surgery, but for a car. I never knew you could snap a cam in half during the removal process.
              He's talking about mixinin up the caps. Yes the cam can break or cause great damage.
              Oh just do remove the bolts from the rocker assm. when you remove them from the head. very confusing at first when they're seperated
              NEW CB
              old Darkcloud : 1990 Accord EX MRT
              new
              DARKCLOUD : 90 ACCORD EX MRT
                You risk damaging the camshaft not the caps...
                when I was in school we took engines apart and put 'em back together...two guys snapped the camshaft.
                One guy didn't put the engine at tdc so when he followed the proper order it was not loaded correctly...snap.
                The other did not remove the cam caps in the proper order and snap.
                ____
