my cb cranks but doesnt turn over
    also check all your cables
    i had this happen to me where i could try and turn it over all i want id and it would but would not fire up cleaned all the grounds and cleaned the terminals
    work much better now
    its always worth a shot
      Did you perhaps buy a car with a broken timing belt ? Is the distributor rotor actually turning when you crank the engine. If not, the belt is broken.
      Why would you buy a car that won't start ???
        [QUOTE=dano28;2572080]Did you perhaps buy a car with a broken timing belt ? Is the distributor rotor actually turning when you crank the engine. If not, the belt is broken.
        If the cam snapped the belts can be perfectly lined up and the dizzy obviously wont turn
        http://www.cb7tuner.com/vbb/showthread.php?t=187851
        sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
        bought from:jokerxfn-tommi-'93cb7ex
          [QUOTE=904drACCORDMANG;2572159]
          Huh ???
            Take off your distributer cap, and look to see how the rotor under the cap is oreintated, maybe make some marks with a marker, put the cap back on, crank the car, take the cap back off, and look to see if the rotor has moved, or changed orientation.
            Otherwise you can take off the timing belt cover and see if your the belt is snapped.
              Originally posted by jofat91 View Post
              ok i changed the main relay nothing i checked for fuel is gettin fuel and spark its getting spark wat else can be the cause
              well you need 3 things for fire. fuel spark and air. if you are getting fuel and spark and you are SURE you are getting them then it must be a problem with air.
              you might not have adequate fuel pressure. you might want to "rent" a fuel pressure test kit from autozone to make sure you are getting enough fuel. idk if this will help or not just a suggestion.
              whoever said check the ignition coil in the steering column i think you mean the ignition switch. since the ignition coil is inside the distributor.
              Parts For Sale
              BIG Thanks to HondaFan81 for all your help!!
                you dont need a fuel pressure tester, loosen the nut comin out of your fuel filter, dont remove just loosen, then turn the key on, your fuel pump SHOULD run for 3 sec, and it should spray gas everywhere with that nut loose. if it does spray gas then u got pressure. recomended fuel preasure is 35-41 psi ive fired my car up with as little as 12 psi.
                  i got the car cause it was 500 bucks and i can get all the parts from my boys the car isnt gettin spark reason for which its not startin there is no spark in the spark plug cables or external coil
                  the guy used too have an msd set up wit an external coil does an f22a1 come with an external coil?
                    i have a 90 dx with internal coil and a 93 lx with external both r f22a1.
                    What year and submodel does the title say?
                      the 90-91 came with internal coil
                      the 92-93 came with external coil
                      like deev said if its not getting spark check the ignition coil and the igniter, both inside the distributor. when my car was not getting spark it was the igniter. it was $50 for a new part at autozone.
                      Parts For Sale
                        92 ex
                          my car has an external coil so i should change the coil if it not the coil take out the distributor and put a new ignitor???
                            i tried testing if the coil had spark and it didnt
                              any info would be a plus
                              can i use the coil of an h23 ?
                                Is there power goin into the coil? If you dont have a volt meter I would visually inspect the igniter, theres usually some physicall evidence, thats if your strapped for cash in a perfect world you would replace coil, cap, rotor, and igniter for the sake of reliability
