F22 vs H22
    i would just do the five speed swap and turbo the F22. With the money saved from the H22 you could build a decent turbo setup. Also I would get some ARP head studs.
      So would I need to get a turbo manifold?
        Only if you plan on installing a turbo.
        Of course, if you have to ask this question, I think you should stop right there. Stop planning on modifying your car. Stop asking what parts you need to buy... and buy a book. Or two.
        I suggest Honda/Acura Engine Performance by Mike Kojima, and Maximum Boost by Corky Bell (only if you think you want turbo... the first book has a lot of turbo info as well, but this one goes into more depth.)
        Without knowldege, you're going to blow that engine up before you even get a chance to enjoy it. Stop thinking about what you should buy, and start learning about what you have to do.
          Ok thanks man, so where can I find these books? Online or what?
            Wherever you find books. Would you like me to read them to you, too?
              omg lol.....i had a lott of fun spraying my stock f22. that is until my wife blew it up...and a good 70 shot makes vtec owners pissed...sohc motors on juice really go. but yea its up to the size of your wallet on the swap.good luck .
                Thanks man yeah I believe I'm just gonna keep the F22.
                  Like everyone said, this topic is one that is better SELF assessed, first you need to know the diffaculty level of swapping a engine, or building one for boost, with the right research, tools, and time one can acheive anything. I can tell you that building your stock F22 to handle a good amount of boost its going to cost alot of money if your not doing it yourself. the head will need to be built, as well as the block, what i would do is find a shop that works solely on hondas, and get it priced. before i learned for my self how to do things (which i do not know everything believe me) i checked a price out to get my f22b build and boosted the shop told me anywhere between 6500-to 8000 dollars, thats with tuning included. now take for example buying a h22 or any other preformance honda engine, and having a shop put it in , also priced engine pull and install that was in the area of 2400 dollars, not including the price for the engine and trans, which in my case was 1100 dollars shipped to my door step. when all was said and done, after buying suspension parts brakes rims tires fuilds axles clutch and flywheel. i spent in the range of 5800 dollars mind you i did all the work my self. what i would do if i were YOU, and this is my opinion, is do the things that are listed in the DIY section, I.H.E. and suspension, and save the rest for a fresh paint job some JDM lights, OEM fogs, and everyone here will love your ride with the stock f22Ax in it.
                  _____________________________
                  91 Accord F22B
                    Originally posted by WP'sFinest View Post
                    Ok I have read a couple things on f22's and h22's and was just wondering what you guys thought. I originally wanted to do an h22 swap but now am thinking of converting my auto to 5 speed and getting a turbo. Would the conversion be difficult and what do you guys suggest? F22 or H22?
                    well yeah i want to swap to h22 but do you think the 98 accord fit into our car but that turbo sounds nice.... isee alot on youtube it give me alittle demo of how it woul d look like
                    CB7 all day
                      Is this thread still going?
                      I think someone should finally make a H22 vs F22 thread . . .
                      IMO it would basically be:
                      Thread Title: H22 vs F22 Debate
                      First Post:
                      If you want an F22 - Swap in an F22
                      If you want an H22 - Swap in an H22
                      Factors:
                      The H22 has Variable Valve Timing and Lift Electronic Control, the F22 doesn't.
                      The H22 has 2 Camshafts, the F22 has 1 camshaft.
                      The H22 has Fiber Reinforced Metal cylinder walls, The F22 has Iron Cylinder walls.
                      The H22 has a different ECU to the F22.
                      The H22 has a different trans to the F22.
                      The H22 has a compression ratio between 10.0:1 and 11.0:1, the F22 has a compression ratio between 8.8:8 and 9.3:1.
                      If you then decide to add turbo (Turbo F22) into the equation you get a whole new set of results.
                      OP you need to decide what you want to do, no-one here is going to decide for you.
                      The VERY first thing you need to decide is what do YOU want?
                      Is there a specific HP you are looking at trying to achieve?
                      Do you want a turbo just so you can "blow off" at everyone?
                      Do you want a reliable car?
                      Do you have a second car to drive while you build / swap?
                      Do you have the funds to support what you want to achieve?
                      My 5.7 LS1 Holden Ute
