I'm going to go to the jy to pick up a distributor for my 90 accord. It has a f22a motor in it but I don't know id it's a a1, a4, or a6; all that it says on the engine block is "f22a". Well, my question is does anybody know what distributors are compatible with this engine and case I can't find an accord at the jy. Thanks.
Compatible distributor
you want 1 from a 90 or 91. they have internal coils. 92 and 93 have external coils. you dont want those. the a1 a4 or a6 does not matter. just try to find the highest quality one you can get. make sure you look inside at the components before you buy it. idk about your jy but here they want $100 for a dizzy. so i would make sure its in good working order if possible before you buy it.Originally posted by 2oClockFox View PostThanks for responding. Do you know what cars I can find those dizzies in?Parts For Sale
BIG Thanks to HondaFan81 for all your help!!
i dont know what you mean by internal coil leak. the coil is a metal object i dont think it has any liquid anywhere inside the dizzy. when people speak of leaks to me it means water leaks or i guess air too. i would try to get the right dizzy for the f series. idk if they are interchangeable with civics or not.Parts For Sale
Oil from the head is leaking into the distributor and that oil then leaks out of the distributor all over the passenger side off my engine and onto the floor. I took the distributor apart and found out the culprit is a worn out seal. I'm just going to replace the seal for now and get a f series distributor when I have more money. As I mentioned before, I don't know what year my engine is and I'm pretty sure its not the original engine, but its there any way to tell what year engine I have.I want to make sure I get the right distributor.
