differences?
    differences?
    Can someone please tell me the difference between a f22a1 and a f22b2? they're both sohc
    there cant be much difference right
    The port geometry is different between the two heads.
    The exhaust side ports are different.
    F22A1 = 0-0-0-0 Even spacing for nice straight flow
    F22B2 = 0-00-0 uneven spacing between #2 & #3 cylinders. Ports are not a straight through design.
    Most people prefer the straight through flow of the F22A* heads.
    There are other things that aren't 100% the same, intake manifolds are not exactly the same. Along with the valve train components, they are interchangeable but not 100% the same specs.
    The bottom end is pretty much identical. The other differences are between OBD1 & OBD2, distributors and sensors.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      The F22A is a much better choice for performance modifications.
        Same horse and torque?
          F22A1 is 130hp, F22B2 is 130hp. Not sure on the torque, but the difference is probably similar to that of the horsepower. (the Wikipedia article on these engines is accurate, if you want to look it up)
          However, modified, the F22A has a LOT more potential (the F22A heads are all the same... the differences are bolt-on parts that make the hp range between 125 and 140)
