Forgot to put back one screw (PS Bracket Mount)
    I forgot to put back bottom screw to hold the ps bracket to the head
    Is it ok it leave it out??? To put it back i have to pull the head off again ><!
    I yank and hammer it it doesn't seem to budge.
    ps as in powersteering bracket, u dont gotta remove the head for that
      I'm talking about the 3 bolts that go into the head
      to hold the Power Steering mount.
      I got top 2 in. Oh well too late anyway. ><! Let hope that screw is not that important.
        Just take the alternator bracket off.
        My 5.7 LS1 Holden Ute
          if i can i would ><!
          That alternator can't come out ><!
          The Alternator nut got stuck when i try to take it out.
          The end of the bolt where the nut coming off is soooooo rusted that it stuck in there. When i try to turn it the whole thing keep on turning. There is no room for me to cut it or anything. So that Alternator Nut got to come off before i can take the alternator out and bracket out ><! FML
          Suck to have 250K+ in Northeast area!
            When the alternator fails, will you remove the whole block to have it repaired?
              Any suggestion? There is no room to do anything.
              I was thinking when it failed I'll take it to the shop and it become their problem ><!
                What are you talking about, the alternator bracket pivot bolt that is like 3.5 inches long and goes through the bracket and the hole in the alternator?
                punch it out with a hammer and punch once you are sure it's free of the threads.
                If you're talking about a stud on the block that the alternator mounts on, use a lot of pb blast. A few times a day. For several days. Be patient.
                I don't know, it's hard to picture and I'm not near my car.
                an air chisel will cut through any nut on your car if you want to go that route.
                but if you just want to roll with two mounting nuts, go for it. Make sure those two are tight. There will probably be some consequence down the road but who knows.
                  Not the pivot
                  the one underneath that go along with adjuster bolt.
                  top have no issue. the bottom bolt is the issue.
                  one end is flat and other is just a nut with adjuster bolt
                    mines held on with two bolts out of three. works fine.
                      Originally posted by XcluziveAZN View Post
                      Not the pivot
                      Ok, that's the one that "slides along" the adjuster bracket as you turn the adjuster nut. And when you tighten it it clamps on the bracket to hold the alternator (or power steering pump) position.
                      I'd spay it every day with pb blast for a week then give it a try. If that doesn't work, give it another week. Once it's out, clean it up with a wire brush and maybe some Naval Jelly to dissolve the rust, or simply get a replacement bolt.
                      If the PB blast doesn't work, since you have to remove the alt. bracket anyway to replace the p.s. pump bracket bolt, I bet that if you just unbolt the alternator bolt brackets mounting bolts from the block the whole alternator assembly will tilt toward the crankshaft pulley (because of the tension from the belt) and you can pivot it and remove it like that, then just do the same thing in reverse with the alternator belt placed slackly around the alt. pulley to put it back on without ever touching the adjuster assembly. The mounting bolts will, effectively, retighten the alternator belt as you torque them in.
                      As to your initial question, which is is it ok to leave the bottom machine screw off of the actual power steering pump mounting bracket that bolts to the block, I think you'll be fine because the primary force acting to pull on that bracket is downwards, so that part of the bracket is always going to want to be pressing against the block anyways when the bracket is secured at the top.
