ELD on the CB3?
    ELD on the CB3?
    hey guys, like some of you know, i used to have a 1990 CB3 Carbed, now swapped to an JDM H22A with a P0F apparently non Vtec ECU, and i'm having CEL 17 and 20,
    about the CEL 17, dunno what's wrong, the speedo works, but when I drive in WOT the cel 17 and 20 come, son any help would be thanked, bout the ELD system, I dunno if the CB3 Carbed had it and if it has the system, where would be located? cuz I wanna Fix the CELS
    thanks in advance.
    Greetings
    ELD aka Electronic load detector is located in teh under-hood fuse box its a 3 wire clip(iirc) near ur battery cable leads.
    Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
    CLICK THE PIC
      Can you post a pic of the ELD? :S cuz i didn't get the iirc thing :S
        I don't have a pic of it, but it is built into the fuse box.
        It can be removed - You will see from underneath it has a 3pin connector going into it.
        My 5.7 LS1 Holden Ute
          it is beside the power and ground leads going into the front of the fusebox...
          more towards the front right...3 wire connector usually white in color.... =]
          -Tyler
            thanks for the replies, anyway i'll try to find it, but, can anyone post a pic of the ELD? =)
            Thanks Greetings !!
              I believe your going to have to get another under-hood fusebox to solve this because this happen the same to me.
              www.PreludePower.com
              BB SQUAD MEMBER #28 V.2
                i'm appearing for some seconds... heres a pic of my fuse box, can u tell me where's the ELD plz
                  Is that it next to the white dots? I'm used to looking at the CD fuse box, like this. Its gonna have a smallish white/yellow connector with three wires.
                  1997 Honda Accord EX-V6:
                  Originally posted by James Matteu
                  You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
                    that is just 1 wire, sorry for the so late answer just hating my notifications, so i'm not finding my ELD :S
                    Greetings
                      bump :S it's a canadian accord, sorry for resurrecting the thread, need to know if it exists on the canadian accord EX, or in the US accord LX, cuz i bought a fuse box of an LX on ebay.
                      Greetings
                        The CB3 dosent have ELD, atleast mine haven`t...The ELD code is not important and the CEL should not be light bacause of the ELD code when the service connector is unplugged....
                        MRT:http://www.cb7tuner.com/vbb/showthread.php?t=164408
                        And on the eight day God created Honda!
                          or maybe thats just the EDM accord....
                            sorry for resurrecting thread, the thing is, the fuse box arrived, but has the clips to stick it to the car broken, is there a way of putting the ELD on my non ELD fusebox? or i have to find a way to put this broken box on the engine bay?
