As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
radiator fan help.
    radiator fan help.
    alright i found out my car has been heating up when its hot and i drive for a while whenever i sit and idle for a while like at a redlight. the radiator fan is not hooked up and all the wires are cut.
    so does any one know a way that i could hook up the fan to the ignition or something so that as soon as the car comes on the fan turns on???? please help
    just hook up a toggle switch if you want a simple fix. Make sure you put a fuse inline with it. It's always best to use a relay like DEI 8617 so that your switch itself isn't handling all the current. I've seen direct wired switches melt before, relays will ensure that doesn't happen.
    http://www.cb7tuner.com/vbb/showthre...=1#post1823428
    My Custom BB6 Dash Swap Thread
      I know that there is a way that you can put a switcha dnt thanks for that feedback man. But does anyone know a way I could just hook a wire to the ignition. Cause I'm short on money. So the switch and relay and fuse thing is out of the question.
        naw man its not that expensive...a switch plus a relay and slide-on terminals wont cost you $30 bux man..n thats from RadioShack
          thats the cheapest its gonna get, ive done this with my headlights and radiator fan, all running off my radio power wire, lol. after two melt downs i pulled out that old issue of Turbo where they wired up a fuel pump with a relay...the relay saves you from having to wire up all your shit a second time after it melts.
            Why don't you just repair the wires? Just buy some wire and some crimp connectors or solder them together and cover with electical tape. That's your best and cheapest route.
              i would love to repair the wires i just dont know where the wires from the fan go to
                Yeah...Just go to autozone and buy sum wire...It will cost you lik $5-$6...And twist the new wire with the hot wire...And run the hot wire from your fan to your ignition...And you will be good...I did dat...But I ran my ac fan to my radiator fan and to tha ignition because my radiator fan went out...And I had to run lik dat for a week...N I dnt recommend using the ac fan as your radiator fan like I did...
                My signature was removed because it was too big.
                  where is the ignition part that i hook the hot wire at from the fan
                    Wait before you do all of that...Check your fuses...The radiator fan is a 15A...Check that and if its blow replace it and you should be good...And if that don't work let me know and I'll post a picture of where its located for u bro...
                      the fuse is good man.
