what should vtec be set at on a turbo engine?small turbo on f22 bottom h22 head.thanx
vtec
thanx man.quick question.why do you say things are wrong with the setup i have?since the swap was done,there has been no problems,no check engine,and is faster than it was.should have bottom end built this winter.Originally posted by deevergote View Postthere are so many things wrong with that setup... but I won't go into that.
There is no set point for where it should be set. You want a smooth powerband. 4800 is where the smoothest vtec crossover usually takes place, give or take.
yea,was gonna get tuned but because im changing the turbo system over winter dident want to speed tuning money twice.so i guess i will wait till spring for a tune on new setup.Originally posted by djcaz_aom View PostGet it tuned. Your tuner will find the spot where your low cam and high cam intersect to give you the best crossover point.
