so my gas gauge is not working properly i put 10 dollar on my car and the needle wont move at all what can be the problem do i need a new cluster ? and another question even if my needle is not working properly should my reserve light should turn on ? help me out because i dont wanna get stuck somewhere because i dont have any gas left
Originally posted by Ramx View Postso my gas gauge is not working properly i put 10 dollar on my car and the needle wont move at all what can be the problem do i need a new cluster ? and another question even if my needle is not working properly should my reserve light should turn on ? help me out because i dont wanna get stuck somewhere because i dont have any gas left
if the gauge still fails to work then you could have a bad sending unit or a bad gauge.
i would think that the reserve light should still function if the gauge is bad. if the sender was bad i dont think it would work. but its possible that the reserve light bulb has blown too.
i had a very similar problem. i put in about 5 gallons of gas and the meter didnt even move. so i knew i had enough to drive down to the gas station i filled it up full tank and it was about 35 bucks. (use 92 because i have a h22)my meter went up with no problem. hope yours will do the same.
Originally posted by H22Artman View Poststart by putting more than just 10bux in the tank at a time. that way you know you have a significant amount of fuel in the tank. if my car is really low. 10 bux wont even move the needle.
Originally posted by Drifting in 808 View Posti had a very similar problem. i put in about 5 gallons of gas and the meter didnt even move. so i knew i had enough to drive down to the gas station i filled it up full tank and it was about 35 bucks. (use 92 because i have a h22)my meter went up with no problem. hope yours will do the same.
Originally posted by TypeG View Postusually, it the Fuel Sending Unit. there's a way to test it using an ohmmeter in the hanyes manual. later.
My prelude cluster's fuel guage stopped working. I could smack the top of my dash and the needle would go up to where it belongs, but then slowly drop back down to empty. I bought another cluster from LKQ and that fuel guage didn't work at all. I exchanged it for a second cluster and that one works fine. I'm sure if you swap your cluster out that should fix the problem.
Also, my low fuel light worked on both bad clusters, so it was independant of the faulty needle.
Originally posted by wherm View PostMy prelude cluster's fuel guage stopped working. I could smack the top of my dash and the needle would go up to where it belongs, but then slowly drop back down to empty. I bought another cluster from LKQ and that fuel guage didn't work at all. I exchanged it for a second cluster and that one works fine. I'm sure if you swap your cluster out that should fix the problem.
Originally posted by Ramx View Postfuel sending unit how hard is this to fix dont tell me i need to get a new fuel pump ?
