Is A 3"R and 3.25"F Drop Too Low For Being Just Shocks And Springs? What Else Would I Need For My Car To Ride Smooth Without Any Wheel /Tire Scraping? I Dont Really Know What Camber Kits, Tie Rods, And Control Arm Bars Do. Someone Explain?
3" Drop. What Else?
Camber kit. Ingalls or SPC ONLY. Cheap crap will break, and put your life in danger.
If you didn't replace your shocks, do so NOW with parts that can handle both the height and spring rate. Koni STR.T should be the absolute cheapest you get for anything that low.
If you're using cheap springs... replace them.
Don't screw around with your suspension. Your life rides on that. Cheap parts will result in poor handling and braking. On a regular ride to the store, fine... but when you're tearing around a turn, or a little kid chases a ball out into the street in front of you... your car will not respond as you need it to.
You WILL need an alignment after doing anything to your suspension.
A camber kit will allow for camber adjustment (google "camber" for a description of what that is.)
Tie rods are the parts that allow for toe adjustment (again, google...) This is the part that is most commonly adjusted when an alignment is done. You don't need anything but a functioning OEM part.
Control arm bars? You're making up parts. There is no such thing.
thanks man, i was planning on getting Sprint Extreme Springs And Tokico Blue Shocks. i really like the drop it gives. right now everything is OEM.Originally posted by deevergote View PostCamber kit. Ingalls or SPC ONLY. Cheap crap will break, and put your life in danger.
Tokico Blues are not made for springs like that. They're barely more than stock replacement... only good for a spring rate that is 15% stiffer than stock, and certainly not for a drop that low. They're not made to handle a drop lower than about 1.2" (the springs that Tokico pairs with them only lower about that much... maybe even less... that 1.2" was merely an estimate.)Originally posted by Jorgian View Postthanks man, i was planning on getting Sprint Extreme Springs And Tokico Blue Shocks. i really like the drop it gives. right now everything is OEM.
wow thanks for the link, i really dont know much about suspension. makes me rethink what setup i should look in to. i want my car to handle comfortably, ride height pretty low, and handle better than OEM. cant afford full coilovers. i dont want my ride bouncy and harsh.Originally posted by CB7_ACCORD View Post
With that type of drop range it is going to have to be on coilovers....
I would say function and forms or even some megan racing coilovers. Along with this a camberkit is needed as stated above. Ingalls will do just fine. Cheap brands won't do at all. Also an allignment is needed after all is said and done.
CB7Tuner Resident Gamer!
PSN: JDMcb7TX
