VTEC issue and question
    Ok I've searched and searched and cannot find the knowledge i seek.
    My girlie's VTEC is not kicking in at all. By all accounts and info found, it should kick in at 5500rpm... there is no CEL showing, no codes to be read, even used two readers. I have removed the selenoid, screen = clean... I have checked oil passages, no blockages... Could it be that the selenoid is bad? Everything is stock on the car, nothing has been modded or changed? I am at a loss. Anyone know what voltage operates the selenoid so I can see if its getting signal?
    Solenoid is a 12v signal.
    Have you checked the oil level?
    My 5.7 LS1 Holden Ute
      Oil level good to go. Sorry forgot to put that one in there...
        Could it be that its an oil pressure problem?? I use 5w-30 synthetic and lucas.
          was there any work done before this happen or just out of the blue it stop working?
          MRT http://www.cb7tuner.com/vbb/showthread.php?t=175158
            She bought the car from her granny... she would forget where she was going, so she just threw it in park where ever she happened to be... including the middle of an intersection... which was the final drive for her.
            Simple upkeep and maintain, alt, starter, belts, A/C upkeep, nothing out of the ordinary as far as I know of. To be honest I'm not sure she ever kicked the VTEC in...
              What kind of motor is this?? F22B1, H22....????
              www.PreludePower.com
              BB SQUAD MEMBER #28 V.2
                d16y8, its a 96' civic, which I am not familiar with at all. Nor the realm of VTEC yet.
