I've getting some good work done yesterday and today.
-Replaced right rear hub, it was slightly loose
-Removed cracked header, ported new upper header
-Adjusted valves
-Installed catch can, had to make a bracket
-New left front upper ball joint urethane boot, cleaned and regreased joint
-Cleaned air filter
-Checked, cleaned cap and rotor
Only a few things left to get it ready, for next weekend!
Window net, move from 944 to Accord
Harness, move from 944 to Accord
Wrap new header
install new header
Replace upper radiator hose
Repalce lower rad hose
Mount new tires
I'd also like to get some stronger steel mesh in front of the radiator to avoid another rock incident, does anyone have any or know where I can get some? Home Depot didn't have anything.
Fancy $25 Ebay catch can, this will keep our intake free of oil vapors, hopefully it vents well enough to keep down crankcase pressure
-Adjusted valves
-Cleaned air filter
Wrap new header
install new header
Mount new tires
