Update:
I fixed my ABS, 2 sensors and the pump motor.
After some brief reading:
Haynes makes no mention of servicing the ABS system, they warn you of severe danger and tell you to take it to the dealership.
Helms tells you much more. From the detailed description in Helms it seems that I need to be able to access the solenoids and control them. There's an abs wiring diagram, but I haven't figured out how to read it yet.
Also, one of the first things I'm going to do is deactivate abs under 10mph. Sliding into an intersection because your breaks are trying to save you is scary!
