Car Cuts Off After Replacing Ignitor
    I replaced my ignitor yesterday and drove it 40+ miles today and had no problem what so ever. Let the car sit for maybe 5 hours or so and then drove it 10 miles tops and it cut off twice like it used to before. No spitting or sputtering no jerking just turned off.. its not hot outside maybe 60s didnt run it hard really. Could it be my Main Relay i didnt replace that.. I think i could hear my Alternator whistle/whine a little.. Any Ideas?
    yes . i would put money on the main relay being bad. mine did the same thing before. i broke the steering wheel once because it shut off going down the road , so i hit the steering wheel so hard it broke the colum.damn it hated that bad relay. get it replaced and let us know if that was it .
      it'll be cheaper if you know how to solder because the old solder contacts tend to come undone in these early models.
      http://techauto.awardspace.com/mainrelay.html
        yeah i read and saw that i dont have a solder but a buddy of mine might. so just basically resolder everything?
          Double check the Ignition Coil, if either the primary or secondary coils are out of spec, replace it again. I had a coil with 27 months of service fail on me, it was a BWD brand.
          Check the Main Relay, but double check it with a fuel pressure gauge on the fuel filter.
          If you suspect the alternator, check the output voltage.
          1997 Honda Accord EX-V6:
          Originally posted by James Matteu
          You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
            haha damn that sucks but thanks man
              is your ignition coil grounded out right?
              (129)Transactions and counting
                I like Lee Hyori also.
                91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
                Neuspeed Super Cup Kit (7/2010)
                TAS rear drum-to-disc conversion (6/2010)
                Above photo taken - 4/2010
                  coil. my shit did that a long time ago. my car eats ignitors...
                  COUPE K24
                    If you haven't already solved this problem, my guess is it's the coil. Not the ignitor. Inexpensive and easier than the ignitor to replace.
